Kadett with volvo engine
J
JM
Hello does anyboby here have any experince with puting a volvo b20 engine in a kadett, has anybody done something like that before?
the reason i am asking is because i allready have a volvo b20 that is tuned to 190hp, and it would make a kadett go really fast! what do you think about that? do you know any sites with pictures on cool kadetts?
//JM
Hello JM,
The B20 machine from Volvo is a 1,9 litres V4, right? It should be possible to put this dimension in a Kadett C-series. But I've never seen this before. Ensure before you start transplanting that the machine and the gearbox have enough space (do you use the original gearbox, or the one from Volvo?). And have a look for the engine and gearbox holders. I'm sure they have the wrong positions. What series of Kadett do you drive? We are only a C-series homepage. Bye, BR.
hello
the volvo b20 is a 2-litre in-line 4, im going to use a volvo m40 gearbox, 4-speed manual, it´s a kadett c coupe!
No experience, but why not give it a try? Shouldn't be too much work. B20 is used in rear wheel drive Volvos like Amazon, right? So the basic layout is the same. Just check it all fits into engine bay and tunnel without major modifications. I'd recommend using the radiator from a 1.9 or 2.0 Kadett C. Then you just have to manufacture mounting brackets for engine and gearbox. Oh and I'm pretty sure you need a special propshaft if you're using the Opel rear axle.
The only thing that you might have to worry about is if it's street legal in your country...
Regards
Jens
@Jens: Tach, besser hätt ich das auch nicht sagen können. Gruß, BR
@JM: You are right, B20 is in-line 4, sorry, BR
@ Big Rik: wollte Dir nicht einfach nachlabern, auch wenn das jetzt so aussieht, sorry. Ich hab' einfach drauf los geschrieben.
Jens
@Jens: Sagt ja keiner was. Dein Englisch ist echt gut. Wo haste das denn her? BR
@ Bik Rik: Danke. Das meiste hat mir Reisen in Australien und Neuseeland gebracht, da war ich zwei mal, insgesamt knapp sieben Monate. Kann ich nur empfehlen, nicht nur wegen des Englisch... :-)) Außerdem treibe ich mich öfters im Forum von www.opeltuners.com rum. Alles Englisch, ist gut für die Fachausdrücke... ;-)
Jens
