cant open my Bonnet
G
gerd
hi
i have a problem with my bonnet holder
i cant open that alone i need some other people to pull in the middle on it
that can i do
sorry for my bad english i am from belgium
greetzz
Dear Gretz (Gerd),to solve the problem, you have to release the center locking pin, which is mounted in the middle of the bonnet. The bonnet get pushed to harhard down on the front 2 supporting rubbers, which are plugged into the front wings left and right.Opening the bonnet, you pull the bowden cable below the dashboard, to pull backwards the spring mouted in the front panel.As the bonnet is forced, the friction becomes to high between the spring and the center (locking pin).If after releasing the center pin, you bonnet is too high up compare with you front wings, you might modify the 2 support rubbers.Hope to help you in this issue. Regards to Belgium Juergen Nicht ueberall wo GTE draufsteht ist auch GTE drin
